Sony Bravia 50w808C - Gliched screen!
    Hello guys. My bravia give up after only 4/5 years old. I post a video from what it does above. .I thoght it waas the tcom,ordered a new one from china ,and the problem stays exactly the same. Apears be an sync signal lost somewhere.
    What is your gess?
    https://photos.app.goo.gl/FSmWjFuHBLcxmVcn8
    Re: Sony Bravia 50w808C - Gliched screen!
    Something going on in the lower left of the screen ?
    You need to take the back off and remove the cable from each side of the screen in turn to see if you get a good picture on one side.
      unfortunally i get same result. each half screen shows some picture but gliching, like if some frames pass to lcd,other(majority) not. it's not syncing or updating the picture... can a faulty cpu or broken solder do that?
        To me it looks like the LCD has suffered some damage on the lower left. Check the tab bonds if someone “washed” the screen and also check the little LCD driver boards. You have to check voltages like vgl, vgh… etc.
