e5-471 no power
    e5-471 no power
    good day,i need help my e5-471 no power,,only charging light comes on
    when i press button switch charging light goes off and on nothing happen.
    check all voltages
    19v present,
    dc ic 3.3v present,5v present
    button switch 3.3v present,
    bios ic vcc 3.3 present
    already reflash rom,but after flashing charging light has gone,
    still not powering up..
    my board id da0zq0mb6e0 rev:e mode: zq0 core i5 tnx
    Re: e5-471 no power
    rsmrst = 0v
    DNBSWON # = 3.3v
    NBSWON# = 3.3v
    pls help i already try to replaced rom ic GD25B64BSIG to winbond 25q64fvsig still not powering up
      Re: e5-471 no power
      Make sure you get +3V_RTC.
      Make sure D17 didn't blown.
      Make sure +3V_RTC have no low resistance.
        Re: e5-471 no power
        tnx meritosari i will check
        upon checking...
        +3V_RTC = 3.3v test ok
        d17 all 3pin is +3v test ok
        any idea my friend,,could you please upload another bios bin for e5-471 core i5
        i already try all the rom at the other thread here still no work..
        and if RSMRST# is always at 0volts what probably the main cause of that,is it sio or bios?
        tnxx
          Re: e5-471 no power
          check all voltages
          19v present,
          Can you send the Schematic of the MB
            Re: e5-471 no power
            Here are the schematics.
            https://www.badcaps.net/forum/showth...07#post1249907
            Last edited by Vesko356; 06-27-2023, 02:21 AM. Reason: Attached schematic removed and replaced with link.
              Re: e5-471 no power
              JaroTech thanks
                Re: e5-471 no power
                this video on youtube is similar to my problem,same board and same problem
                https://www.youtube.com/watch?v=YIgFO8fMDHc
                  Re: e5-471 no power
                  check Page 42 Schematic since PCH integrated in i5 CPU it should get
                  +3VPCU or +3.3VDSW
                  Page 40 Schematic if you don’t have +3VPCU PCH will not respond correct me if I am Wrong any one? to have PLTRST ?
                  Take a wire and GND all pins of IT8587 EC to Discharge the Chip without any power take off the RTC Battery
                  Clean IT8587 heat up the all pins with hot air and test again
                  Check +3VPCU PIN 26.50.192.114.121 one of this pins
                  Check VCC PIN 11 +3V
                  RSMRST
                  NBSWON
                  In Quanta MB if you don’t have RSMRT it’s BIOS or SIO chip fault
                  if i am wrong correct me Guys ?
                  but in 4th generation CPU power sequence Step by Step
                  1 VIN
                  2 3VLP
                  3 EC ON
                  4 3.3VALW + 5VALW
                  5 SP OK
                  6 1.0VS + 1.8 VS TO CPU
                  7 PWRBTN
                    Re: e5-471 no power
                    techtiger thanks for support
                    measurement at it8587
                    pin 26=3.3v
                    pin 50 = 3.3v
                    pin 92 = 3.3v
                    pin 114 = 3.3v
                    pin 121 = 3.3v
                    rsmrst = 0v
                    nbswon = 3.3v
                    pin 11 vcc = shorted to ground
                    +3v rails are shorted,check C269 Cap ok
                    before r232 shorted..pls help
                      Re: e5-471 no power
                      pin 26=3.3v
                      pin 50 = 3.3v
                      pin 92 = 3.3v
                      pin 114 = 3.3v
                      pin 121 = 3.3v
                      rsmrst = 0v
                      nbswon = 3.3v
                        Re: e5-471 no power
                        Guys i have up lode pic of it8587 can some one tell why pin 11 vcc = shorted to ground is it R232 causing it VCC shorted or some thing else or BAD IT8587 ? BAD BIOS ? help
                        rsmrst = 0v
                          Re: e5-471 no power
                          Hi, is it really short with about zero ohm to ground or you just have zero volt on pin 11? Which means you don't have the +3V, do you have the +5V?
                            Re: e5-471 no power
                            pin 11 is ok/not short/ but 0volt reading when you pull out the r232 resistor,which means before caps 269 and before r232 the line of +3v is already shorted to ground..
                            i already pulled out and measured all the line of +3v but all i pulled is good..
                              Re: e5-471 no power
                              What are the voltages on pins 1,4,5 of PQ15 and pins 1,2,3 of PQ16.
                                Re: e5-471 no power
                                Pq14
                                1=0v
                                4=0v
                                5=5volts
                                pq16
                                1=0volts
                                2=0volts
                                3=3.3v
                                pq16 pin 1 is shorted to ground
                                  Re: e5-471 no power
                                  in page 27 at card reader section many caps are shorted
                                  c346
                                  c347
                                  c348
                                  c349
                                  c377
                                  c544
                                  c543
                                  c584
                                  L34
                                  c542
                                  at page 28 codec ado alc283 these caps are shrted
                                  c330
                                  c310
                                  c332
                                  c331
                                  c357
                                  i already out all caps and ic all are good
                                  what is avdd and dvdd? why is it shorted in cardreader and audio codec..
                                    Re: e5-471 no power
                                    This is normal, if you have a single short circuit to ground on the + 3V rail, all components measured will be short to ground. In addition, you can check the PQ31 transistor. AVDD is connected to DVDD through L34 and DVDD is connected to + 3V.
                                      Re: e5-471 no power
                                      jarotech thank you,i already lift off pq31 and test
                                      pq31 pin
                                      1=0v
                                      2=9v
                                      3=0v
                                      pin 3 is shorted to ground,so i lift off pq31 to check,but still shorted at pin 3 even pq31 is pulled out
                                        Re: e5-471 no power
                                        What can I say, continue you are on the right track (or rail).
