Samsung Ln55b650t1f Part Identification
    Re: Samsung Ln55b650t1f Part Identification
    Originally posted by ngth82 View Post
    +1 to BudM and the big scary cap comment. It's no joke. Don't die.
    Just getting to my e-mail... standby goes down to 1.3V? STBY isn't loaded down when the TV is off (e.g it's within nominal), and shouldn't be when the TV is on.
    Edit: also, you are missing a few pin numbers... You have pins 1, 2, 3, 5, 7, 9, 11, 13, 15, 17, 19, 21, 23, 25, 27, 29, 30... where are the rest?
    Correct. When Powered on, standby voltage jumps from 5.18 -> 3.31 -> 0.155 -> 1.3 -> 1.6 -> OL -> 5.18 (all in about 2 seconds)
    All the pins I left out are not wired, just open holes in the connector.
      Interesting... can you check the four rectifying diodes on that power board? Wait until the big caps discharge first. If you can, either remove the diode from the circuit, or just lift one leg off first.
      -Thomas
      I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
        Originally posted by philtvman View Post
        Voltage between filter caps
        Power Off with Main Disconnected from PS: 387
        Power Off All Connected: 168
        Power On: Spikes to 387 and drops back to 168
        Tested the SB and yes, same result. Steady at 5.18 with Power Off.
        When Powered on, voltage jumps from 5.18 -> 3.31 -> 0.155 -> 1.3 -> 1.6 -> OL -> 5.18 (all in about 2 seconds)...when the button is pressed and these voltages are bouncing around, the standby light turns off.
        Ah, so the standby light does not stay on solid then, that this important if, unless I read your post #1 wrong and thinking that the standby light stay on when turn the TV on and then goes off when TV is turned off.
        So right now we do not have steady Standby power supply output.
          So in self test mode (power supply board not connected to the main board) the PS-ON pin has the pull-up resistor to simulate PS-ON control signal and the PFC Boosted Voltage is working fine,
            So what Voltage do you have on INV-ON and I-PWM pins when running the power supply board without connection to the main board but everything else are still connected? Do see the backlights come on?
              Are these the four you are referencing? Thank you for your patience!
                Yes, the backlights all come on with the main board disconnected.
                INV-ON: 7.3
                I-PWM: No wire in this connection
                E-PWM: 4.9
                Correct, the standby light will be on when the TV is OFF and turn off when the power button is pressed. It turns back on after about 2 seconds.
                  Maybe unhook the tcon from mainboard, keep mainboard connected to powerboard, see if you get proper steady voltages there at your powerboard connector.
                    Check cable from powerboard to mainboard, see if there are any dark or burnt looking terminals, can also check for continuity from end to end, Sometimes I use stripped bread ties so as not to spread out or distort the terminal ends.
                      No change in voltages when the T-Con was removed from the Main.
                      Also thoroughly looked over the Main/Power cable, everything looks good there.
                      Thanks for your help!
                        Reply above, meant to quote it you
