Hi evryone
Customer applied copper heatsink on ram modules and this caused some shorts on the graphic card.. the card is detected on windows as secondary, gpuz shows bios info, but nothing about memory and gpu clock. Seems ram modules related. If connected as primary card pc does.not boot (only one time it booted with vertical lines (channel c and d vertical lines, but i m not sure).
All Voltages rails are present, ram modules heat up also the gpu aswell
I tried with dmgg.py and this is the result, i have errors.but no faulty chip detected.
Should i replace 6 ram modules? Bad gpu? Thx!
