dell E6410 no power
    dell E6410 no power
    dell e6410 la-5471p no power i measured the ic max17020e the vin is 19 v put no 5 v or 3.3 v should i replace it ?
    Re: dell E6410 no power
    Which voltage rails on PU19 are missing ?
    There are the 2 x LDO low current rails supplied by this Maxim device.
    There are 2 x high current switching rails supplied by the same device.
    What is the voltage on pin # 4 (ONLDO) of this regulator ?
    Also, measure the voltages on the following pins of PU19:
    pin # 5 (RTC) - should be 3v3
    pin # 7 (LDO) - should be 5v0
    pin # 14 (EN_3V_5V) - signal enables / disables the switching regulator (5v)
    pin # 27 (EN_3V_5V) - signal enables / disables the switching regulator (3v3)
      all the above is 0 volt
      just pin 6 =19 v
        So the ENABLE pins for the LDO and switching legs of this Maxim regulator are OFF = 0v. This will then result in each of the 4 power rails to be DISABLED.
        The ENABLE pins are driven by the EC controller @ U36.
        Confirm the RTC_CELL battery voltage on this logic board.
          i replaced the rtc battarey and now pin 5 = 2.6 volt
          the same rtc battery volt but there is no ldo or en volts
            Confirm that VBAT is present to power U36 (RTC_CELL_VBAT).
              Do you have AC_OK signal from charger ic ?
                (RTC_CELL_VBAT) pin 64 = 0 v
                  if there is a boardview i want to find r544
                    Attached. It is from a paid sub that is locked.
                      https://www.badcaps.net/forum/showthread.php?p=868883
                      Download from post #17 if you don't have allegro viewer brd file from piernov
                        Done thank u bro
                          Excellent. What was the fix ?
