Please help unlock 845 g8
    hi , please help me unlock hp elitebook 845 g8
    i have already tried rc unlocker it says wrong bios chip
    here are both 32 mb dumps top and bottom
    thanks
    Re: Please help unlock 845 g8
    Try working with this file.
      hi , it does boot but is says it is locked and not give the opertunity to write pass at all
        Try
        Become a Badcaps supporter
        Thanks to all supporters.
          there is a problem with hp endpoint security controller on the unit
          next screen - system locked to turn off please press power button
          and this is it
            and this is it
            Re-flash the bios file I posted and the original EC file. Can you go to bios settings during the first boot ? Use the F10 button.
              now black screen and full speed fan
                Anybody?
                  if you open your 2 files with hxd yo will not find thee usual form of bios....so certainally theres another 3 chip
                    there definately only 2 bios chips
                      ur mbd is with AMD Cpu or Intel CPU ???
                        thanks
                          amd
                            Not booting , full speed fan and black screen
                              it is finally unlocked , but i have hp security controller error
                              can somebody help with this error
                                how did you read and write the chips? did you desolder them or is it possible in circuit?
                                  Whether or not the chip has to be removed from the motherboard is up to your programmer. With a trusted programmer there is no need to remove the chip from the motherboard.
                                    Ok now I was able to get the dumps, but only by unsoldering the chips.. Now I am trying to unlock. I used the files posted above but without luck. Can somebody help?
                                      Try
                                        Please help remove hp endpoint security controller error
