Msi rx5600 xt no post
    Hi evryone
    Customer applied copper heatsink on ram modules and this caused some shorts on the graphic card.. the card is detected on windows as secondary, gpuz shows bios info, but nothing about memory and gpu clock. Seems ram modules related. If connected as primary card pc does.not boot (only one time it booted with vertical lines (channel c and d vertical lines, but i m not sure).
    All Voltages rails are present, ram modules heat up also the gpu aswell
    I tried with dmgg.py and this is the result, i have errors.but no faulty chip detected.
    Should i replace 6 ram modules? Bad gpu? Thx!
    Re: Msi rx5600 xt no post
    on AMD there is mostly many chips bad
      What do you mean? Rails voltages are present
        The results returned after testing vram but the number is large, so the possibility is that the gpu is open, the vram is still intact
        PC work for schemaltic:
        Mainboard: Gigabyte Z68XP-UD4
        CPU: I3-3240
        Ram: 16Gb
        Graphic Card: GTX 1050Ti zotac 4Gb Mini
        SSD: 120Gb
        HDD: 2Tb
