Right 1/3 of LCD screen is dim. Picture is good otherwise. Research suggests LED strips, but thought I would see what you pros think before I fix it until it is broke. Thanks for help/suggestions.
Toshiba 55L310U
Re: Toshiba 55L310U
Dim side-closest to camera lense-is the darker side. LEDs glowing but very poorly and must be the LED3 circuit lotas suggested. Looks like 12 strips total. So it must be 12 vertical strips. Could I get away with just replacing 4 strips instead of all 12? Amazing this TV is almost not worth fixing.
EDIT: Pulled led strips and found one bad bulb on far right (fourth from bottom) and another on fourth strip from right bulb (upper-most).Last edited by ShortCircuited; 08-17-2022, 01:11 PM.
