MAG Inoovision LT716S Model 700P
    Hello friends !
    First I want to thank you for the oportunity of join your forum, thanks God I found it, I really apreciate your time reading this and more than it, all the help that I know you will give me to solve my problem, and now the question is about a Mag Innovision LT716S (Model 700P I guess) I have this monitor and the screen goes off 2 or 3 seconds after I turn it on, the litlle green led still on solid (not blinking) and every time I turn it off and then on it goes the screen on again for 2 or 3 seconds.
    Does sombody have solved something similar...
    Thanks you a lot in advance for your time and help on this
    Sincerely
    Jesus Cantu
    Re: MAG Inoovision LT716S Model 700P
    replace cap there are six 470mF/25VDC/105deg and one 330mF/25VDC
      Thanks a lot for your answer, I'll try it... !
        See the posts with pics under "MAG Innovision LT716S Model 700P, seven bulged Xunda's "
          Hello again... I´ve just change the caps and it´s the same, is there something more that I can do ?... Thank you for all !
            Somebody knows where can I get the schematic of my Mag LT716S ?...
