Benq power board failed, no backlight
    I have a HP LCD monitor with benq power board. Last week, when i turned it on, the backlight turned off right away. I can see the image moving on the screen using flashlight.
    I found out the whole thing was made by benq and there 're some discoloration( lititle darker) near the transfomer .
    I borrowed a ESR meter from my friend and all the caps are still within range. I suspect it is the transisitor that near the transformer.
    The transistor is FU9024N , a p-channel transistor, and i only have a multimeter
    Anyone know how to to test it using the multimeter?
    Re: Benq power board failed, no backlight
    Well you can find a few transistor test methods out there. i always skip them because my multimeter has a nice little feature where you slot the transistor in a socket and switch it to "Transistor test" mode. look around and you should fine one.
    Stats Reset Every Month.
    My Forums
