Dell E153FPc lcd with bad caps in the power inverter board
    I hope this is in the correct thread. Regarding TAICON caps, I have a Dell E153FPc lcd with bad caps in the power inverter board (715L1074-H). The obviously bad one is a HERMEI 1000uF 16V. It had swollen upward out of the plastic coat to the point I thought it was a different type capacitor. There is another of same specs, still looking normal but I figure to replace it based on the failure of its sibling.
    I have two TAICOM 1000uF 16V (10x16mm) of the "HI" series. Would these be an acceptable replacement? Taicom spec sheet indicates a ripple value of 2000 for this paticular cap.
    The other caps are smaller HERMEI 470uf 16V (purple jacket w/ silver lettering), one 150uF 25V, others are small non-suspect values.
    Thanks in advance for any help.
    Re: TAICON Capacitors?
    Welcome Dixie.
    If you repost in the Troubleshooting TVs and Video source section, you should find a more direct adivice (eg. replace them all, or you should check this pieces): this is a general thread about Taicon caps.
    Anyway I don't know if Taicon HI caps are good enough, but I think you should replace those 470 uF Hermei too because it proved to be an unreliable brand.
    Zandrax
    Have an happy life.
      Re: Dell E153FPc lcd with bad caps in the power inverter board
      topic split to section
      i think HI would be fine
        1000uF TAICOM sounds fine with 2000 ripple.
        I agree about changing the other HERMEI out too.
        Mann-Made Global Warming.
        - Dr Seuss
          Many thanks! I was planning on replacing the other Hermie caps as well, good to have independent recommendations though. I am hoping that the recap will recover the lcd. I checked everything and found only the real obvious problems on the inverter board. The symptoms fit the diagnosis by others online, i.e. power button lights then immediately shuts off.
          This is first try at an lcd project. I have been recapping motherboards for about a year with mostly good results. I have mainly used caps recovered from damaged (dropped and broken) boards but am hopefully going to be able to build up a supply of new components.
          I will let you know how the lcd attempt comes out.
          Thanks again,folks.
            If unsure, just replace the 5v capacitor, usually this is the only controlled rail in those psu`s, but sometimes it is the 12v rail.
            Another very common failure with this symptoms are open circuit pico fuse, which could be caused ba the bad caps or simply by ageing.
            Picfo fuses should usually test for 0,0R, but they may develop a higher resistance over time.
              I got the project finished about 1:30am Sunday. I now have a nice bright lcd, and a jealous son-in-law since he didn't have time to fix it and passed it to me .
              Sorry for the bad quality photos, I can't find my mini-tripod and I was unsteady when taking the shots.
              Thanks to all who offered suggestions and tips.
              Bill
                Fantastic! I have a couple of these monitors that I need to revive. Where did you get your capacitors for this project? And which ones did you end up getting?
                  Thus far all the capacitors I have been using are salvaged from other equipment that is beyond epair (burned motherboards and other pcb).
                    I would recommend Panasonic FC caps from Digikey or e-mail Topcat with your cap values.
                      Wonderful! I've got three of these that are all showing similar signs (blacklight turns off after a sec or two of being on, but menu is still there with a bright flashlight).
                      I'll have to try this out.
                      peace
                        hmm, can't edit here I suppose.
                        Anycase, caps come in yesterday from thecapking.com and after a few hours of soldering and assembling, now all three monitors are working great!
                        I only replaced the two 1000uF HERMEIs and now the backlight works great.
                        peace
