Compaq presario CQ56 With Power Issue,schematic of mobo
    please I have these presario CQ56 With power problem,When I plug inn then charger the power jack led does not come on and i don't know what to measure first
    Mobo number is
    DA0AX2MB6E1 REV:E
    Or if I can get schematic of mobo
    Thanks in advance
    Re: Compaq presario CQ56 With Power Issue
    [QUOTE=manuel.it.solution;962922]please I have these presario CQ56 With power problem,When I plug inn then charger the power jack led does not come on and i don't know what to measure first
    Mobo number is
    DA0AX2MB6E1 REV:E
    Thanks in advance[/Q
    are you using a original 90W adapter ? in the MB Dc in Conn test the voltage on pin 3? after PD16 pin3 ? PQ55 supply on all legs ?
      Making my checks i relies PD1 was short to ground and after changing it the motherboard is working perfectly
      thanks very much for the schematic
        Re: Compaq presario CQ56 With Power Issue,schematic of mobo
        T.q.tech tiger.
