hp pavilion g6 schematic
    Re: hp pavilion g6 schematic
    thanksssss
      thank you piernov
        thank you piernov
          thanks
            Looking for hp daor33mb6fo rev fpavilion g6 board view
              Thank
                Re: hp pavilion g6
                Originally posted by piernov View Post
                Quanta R33 motherboard, schematics and boardview attached. OpenBoardView can be used to open the boardview.
                C22 and C6 look bad, not sure about C11.
                You should remove at least C22 and C6, and check if +VIN_BLIGHT is shorted to ground. They will need to be replaced later, but for now for testing they can be left off.
                Also L5 and L63 just above (this last one is not present on the schematics or boardview, and on your board they are resistors so you may have a different revision) may be bad. Check the resistance across them, should be 0.
                I finally found the schematic I've been looking for for a long time, thanks
