PROBLEM: Has trouble starting warm but will start cold; later on, it would not start even when cold (makes a ticking sound with the PSU fan running), even though the power supply did start with no external load when out of theoscilloscope.
FIX: Replacement of electrolytic capacitors (all low voltage - two 105C Chemi-Con KME and the rest being 85C Nichicon VX) on regulator control board nearest the auxiliary SMPS (all of the electrolytic capacitors on this board were around this area which were then replaced).
Also replaced two 85C Nichicon VX units near the external fan connector as a good measure.
The replacement electrolytic capacitors are all low-ESR units.
In switching power supplies, I would not recommend under any circumstances, 85C-rated electrolytic capacitors and I would also only recommend using low-ESR units in all sections, except for the primary (200/250V or 400-450V) units.
