Toshiba Satellite L850 schematic diagram
    Hi Everybody,
    I got a Toshiba L850 Laptop and it doesn't power on. I already checked the adapter and the DC power and got to know that they work correctly.
    Now I need to check the mother board and couldn't find the schematic diagram on Google. Is there any suggestions to find it? Thank you!
    Re: Toshiba Satellite L850 schematic diagram
    bump
      here is a link, https://www.badcaps.net/forum/showpo...03&postcount=4
        Originally posted by trebo View Post
        Thanks trebo. I saw that one but I think it's little bit different than my actual board. I can't find some numbers on my mobo which mention in that schematic. May be it's only for C850/C855. My one is L850. Thanks any way!!
          bump
            what's the model of the motherboard?
              Toshiba satellite L850
                That's not the M/B number/code, you will find it printed on the M/B,
                  thanks for the diagram
                      thank you sir
                        I also need the motherboard schematic of laptop Toshiba Satellite L850. Motherboard number that i can see there is PLF/CSF 45W UMA & DSC MB
                        It has AMD graphics chip. Turn ON, all voltages are present but no video. In my power supply it shows 1.45AMPs. Graphic chip replaced but no luck.
                        Much appreciated for any help...
                          Than U
                            hello could any one help with finding schematic diagram for toshiba satellite l850-1L1 or toshiba satellite l850-1LE schematic diagram "i min is diffrent than the pdf above "
                              Hi
                              I am too having a similar problem. when I press on/off button the power comes and LEDs go off after few seconds. need to start troubleshooting. Any similar experiences by other colleagues.
                                thank you somust.
                                  me too
                                    Can it be fixed?
