Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    It works bro , thank you dani981 and mr. Qurash
      First extract as is with UEFITool (use search) Lenovotranslateservice and Bootoption.
      Replace as is Lenovotranslateservice and Bootoption with the files you extracted.
      If you have black screen or freeze try ctrl+alt+del or power on/off few times. If not working try with a hdd with password.
      If you get no image and 5 beeps:
      Use a hex editor and fill with ff the following files:
      VSS2 store Data address: 800064h Body size: 26F9Ch
      VSS2 store Data address: 82701Ch Body size: 26FE4h
      FTW store Data address: 84E020h Body size: 1FE0h
      (ex. from address 800064h to address 800064h + 26F9Ch fill with FF)
      and replace EVSA store Base address: 880000h size: 20000h with the file attached .
      You can check the address and size in your bios dump with uefitool.
      Follow the post from dani981 post 490.
        hi Bro, i really want to follow your instruction but how come i didn't see any "EfiSystemNvDataFvGuid" in the BIOS Region
          hello
          need patched bios file Thinkpad A475 CPU. AMD PRO A12
          Thank you
            Use Uefitool 0.27.0 for replacing the 2 files and Uefitool A56 to see or comfirm the address.
              Originally posted by dani981 View Post
              Overheating. CPU fan clean? Bios update https://support.lenovo.com/us/en/downloads/ds035965Motherboard serial no? For example:T440S
              VILTO NM-A051 REV: 1.0
              cpu fan is clean,serial board is VILTO NM-A052 REV: 1.0 i try change ssd with a new one.
                There is no need to wait 10-15 seconds before pressing enter when hardware ID is bypassed. Stop wasting your time
                  hi
                  check HDD, RAM!!
                  another bios try it.
                    Hey!
                    Having trouble with these X1 Yoga Gen 1 models. Either just 5 beeps no display or when I do get display, it will always restart after pressing F1.
                      hi
                      check HDD, RAM!!
                      this bios is 8mb,the org bios is 16 mb.i check ram and ssd,its ok,i try without any drive and its the same problem.If i try to write mec 16xx can you help me with schematic pin connection and a good bin for EC MEC 16xx?thank you very much,i aprachiate!
                        Originally posted by RethoricalCheese View Post
                        Hey!
                        Patched this file.
                        Well, maybe good.
                        Please feedback to me.
                          Excuse me.Dont see size file
                          Goood ec file plus 1633 ec connect j tag pdf
                            Hello!
                            Can someone help with BIOS patch for attached T440?
                            Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                              Originally posted by Karol View Post
                              Hello!
                                Patched this file.
                                Well, maybe good.
                                Hey! Already tried with 100% identical file. It will always restart after pressing F1.
                                  Try
                                    Hello and thank you for the reply.
                                    It's acting strange... when I program the flash chip it give me an error every time to the same address 0x400058 when verify the programming.
                                    If I start the notebook with how it is programmed it give me 5x5 beeps.
                                    When I program the original file it work perfectly, verify is correct.
                                    So I start again the notebook with password, only to check to see is OK, and it is.
                                    Now I let the motherboard more time to discharge and read again the flash.
                                    Can you try patching again this file?
                                      Try
                                        thank you very much for all your time i solve it.
                                          @CraterM
                                          @dani981
                                          I figure it out. The notebook it have 8MB flash. Probably someone try to unlock and replace the chip. Very strange that it start and ask for password. I discovered only when I change the chip
                                          So, I resolved by changing the BIOS chip, write one ME clean BIOS dump. After that I patch the new BIOS.
                                          Thanks for your efforts.
