Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Originally posted by bogivet View Post
    Hello, can somebody patch this bios? Lenovo T440, motherboard NM-A102. Thanks.
    Test and update make sure to reply if its working
      Not working, only 4 blinks of power switch.
        did you follow instruction above taking out battery and cmos plus holding down the litlle switch if available on board ? sometime leave for 30-60sec just charger cable
          Do you mean about dip switch before power on, or something else instructions?
            *Remove all batteries (main battery and RTC battery).
            *Patch the bios and make sure to verify it so there aren't any errors when writing.
            *Hold down the small switch on motherboard
            *Connect charger (laptop should start automatically)
            *Wait. It might even take minutes and laptop will beep/restart a few times.
              Not working, I do everything by instructions, but the same thing.
                If still same issue try this file and follow instructions above
                  i have 8mb bios in T440 but i can only see 16mb
                  could i ask for help in locating 8mb DXE patch
                    post your bios dump
                      here is dump
                        here is dump
                        Reupload bios no good make sure to verify when reading chip
                          thanks for pointing that out
                            This dump is ok, thank you.
                              Thanks for the reply
                                Check and update please
                                  Are you sure that nobody change the BIOS chip?
                                  See post:
                                  Originally posted by Karol View Post
                                  @CraterM
                                  @dani981
                                  I figure it out. The notebook it have 8MB flash. Probably someone try to unlock and replace the chip. Very strange that it start and ask for password. I discovered only when I change the chip
                                  So, I resolved by changing the BIOS chip, write one ME clean BIOS dump. After that I patch the new BIOS.
                                  Thanks for your efforts.
                                  Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
                                    See post:
                                    If this is the case most likely a error will occur on screen
                                      Re: Remove psswoord
                                      please patch for password
                                      i tryied but not found bootoption in this file
                                        Re: Remove psswoord
                                        Because not read correctly
                                          i patched
                                          it go to hw id
                                          password when pressing enter or space two time
                                          no response
