missing 5 volt rail and power flash problem.. thanks
need hp mini 110-3004tu schematic
Re: need hp mini 110-3004tu schematic
Originally posted by anshad View PostA single laptop may have multiple boards from different ODM manufacturers. So many technicians including me don't save schematics by Laptop model number. Please share the board part number and hopefully someone may share the schematic with you.
This is Flex/Arima 40GAB5400 ODM manufactured board for HP. I don't have this particular schematic. This lap also has a Quanta Annika model board which has schematic available. But the Quanta schematic is vastly different from the Flex board, so no use to you.Last edited by anshad; 03-21-2019, 11:04 AM.
Originally posted by anshad View PostThis is Flex/Arima 40GAB5400 ODM manufactured board for HP. I don't have this particular schematic. This lap also has a Quanta Annika model board which has schematic available. But the Quanta schematic is vastly different from the Flex board, so no use to you.
i just need to pin point where is my 5v rail start..
3.3 volt is present and i can switch on my laptop for a temporary of second
and that cause power flash..
and also i cant find my 1.8 volt for the RAM memory vcc.
is it possible my 5volt missing causes 1.8v missing too?
Re: schematic diagram
Could be:
ZQSA vendor Quanta:
https://www.badcaps.net/forum/attach...1&d=1390133949
https://www.badcaps.net/forum/attach...5&d=1449801928
or
MBPNCBT414
https://www.badcaps.net/forum/showpo...70&postcount=3
Good idea are You should mention your MOBO's code/ID and search first.
How to search: First need login and put * symbol on your word on the beginning and at the End at box search.
https://www.badcaps.net/forum/showthread.php?t=75473
Originally posted by anshad View PostThere is a certain sequence in which the power rails are enabled. Although the sequence might be different for platform to platform, usually the 3.3v and 5v came first and the RAM supply secondly. Look for 6.3 volt filter caps. It is less likely for the board to use 6.3 volt rated capacitors anywhere except the 3v - 5v standby section. Tghen you can identify the coils and the Ic which drives them.
can you give me some dc to dc chip or regulator ic part no. that produce 3 volt and 5 volt dc especially with hp laptop mobo? from there may be i can find it on my mobo
