S301LA Schematic Request
    I'm searching for a schematic for a S301LA board to make sense of all this...
    I'm still working on an S301LA board where I thought that the problem was with the two A5KNA mosfets. (With some alcohol on them, you could see them thump repetitively.) After removing the 10k Ohm resistor, I supplied voltage/current with my own DC supply, connected after the mosfets to find what I thought was a bad cap, and burned up the charge management IC (PU8801). After ordering/replacing the IC, the chip fried again. However, this time power was supplied by the laptops own power supply. I thought this was very odd considering I hadn't put the 10k Ohm resistor back on the board...
    Your experienced help would also be great, but I'll start a new thread for that in the appropriate place.
    Thank you!
    Re: S301LA Schematic Request
    maybe that helps...
    https://www.badcaps.net/forum/showthread.php?t=54934
      Post #67 https://www.badcaps.net/forum/showth...t=54934&page=4
        Unless I'm mistaken, the archive file in that post has only the boardview file and not a schematic with it. I've read through that string to help troubleshoot, but still having a hard time.
          There`s no schematic available,only boardviews .
            I just solved the board issue. Turns out that cap PC8802 near the power-input MOSFETs was indeed bad. What's interesting is that this cap, (and many others), were initially tested for a short-to-ground using Diode Mode on my multimeter and didn't trigger. After changing the Charge Management IC (PU8801) and watching it 'splode, I rechecked caps using Resistance Mode and saw that it had a crazy low resistance indicating a failure. Changed both IC and capacitor and the board came back to life. Thanks for pointing me at some options to help, though.
