Hi masters i need dell precision m3800 aau00 la-c011p rev: 1.0 schematic
Need dell precision m3800 aau00 la-c011p rev: 1.0
Re: Need dell precision m3800 aau00 la-c011p rev: 1.0
Let me guess, battery not charging issue? Did you manage to fix? I've got about 3 boards with this issue that I haven't been able to fix. Changed charging BP715 ic but it didn't work... replaced a blown capacitor, same problem.... also looking for the schematic but I can only find the one for the earlier 2013 board... any help would be appreciated. Thanks!
you hit the goal. exactly the same problem on 2 machine, replace bq715 and some suspicious parts and no luck. did you find any fix? 3.3v on battery connector for blue, white and purple wire and nothing for yellow when battery is NOT Connected and after connecting battery voltage drops on purple near to 0. maybe there is wrong with kbc. did you replace kbc?
Hi darrkoo, I've recently got my hands on another one of these machines. Same symptoms, will not power on and not charging battery. I noticed you reference three components, what am I looking for exactly? I've checked over the board nothing burned or charred. No hotspots when power supply is connected... Do you have the values/info for these components? I'll try to source and replace.
