Shuttle SS40G FS40 confirmed bad?
    Can anyone confirm if the Shuttle XPC SS40G FS40 board has the bad caps?
    I have one that has exhibited the symptoms:
    Started taking long to turn on, had to warm up for a while.
    Now will not boot, only sits there with fan on max.
    I'm also worried about some other Shuttle XPCs I have, SS51G and SK41G, are they past the capacitor plague era? How far does it extend in the Shuttle XPC line?
    JD
    Re: Shuttle SS40G FS40 confirmed bad?
    Haven't specifically encountered those models, but older Shuttle FV/SV-24/25s had bad Gloria caps by default. Shuttle boxes also often use Channel-Well PSUs with Fuhjyyu caps, usually pronounced 'Fukk-you' for good reason.
    They should work OK after a recap of both the mobo and PSU.
      time to inspect it.
      you need to blow the dust out anyway.
      open the psu too.
      i just had a shuttle shoebox pc in here with bad caps in the mobo and psu.
      it was a socket 478 board
        A lot of the Shuttle PSUs contain CapXon caps but they fail due to heat issues.
          Keep in mind that CapXon is a mediocre brand as well.
