is there anyway to remove or bypass the 30min timer of an hm70 chipset after upgrading cpu to core i series.
hm70 chipset 30min timer
Re: hm70 chipset 30min timer
Originally posted by bigbily09 View Postis there anyway to remove or bypass the 30min timer of an hm70 chipset after upgrading cpu to core i series.
That's absolutely crazy. It works perfectly but arbitrarily decides to shut down the computer after 30 minutes because you didn't buy a system with a better chipset to begin with.
All that said, I have no actual solution to your problem, sorry.
Learning something new every day Crazy.
Found this:
https://www.tonymacx86.com/threads/a...utdown.225447/
Originally posted by age80 View PostYou are right...
HM70 supports only intel pentium dual core until B980 and intel pentium like 1000M
You'll need HM76 or HM77 for an iCore
bigbily09 received an answer this morning, and I don't know why he create another topic in different forum section (probably expecting a miracle to happen this way) about the same thing.
https://www.badcaps.net/forum/showpo...62&postcount=2----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Originally posted by shovenose View PostIs the chipset a direct replacement? They could desolder the old one with a BGA rework station and put the better one?
Originally posted by Vesko356 View Postbigbily09 received an answer this morning, and I don't know why he create another topic in different forum section (probably expecting a miracle to happen this way) about the same thing.
Hello.
It's been a while, but I'll share my experiences here on this topic.
Originally posted by pongis View PostRe: hm70 chipset 30min timer
i have solution. me not help to clean so need mod me region.
inject this me region
I have laptop ASUS X401A-WX095V (intel HM70 chipset) - originally came with Celeron B820. I swapped CPU to i5-2410M (from Toshiba Satellite Pro C660 on HM65 chipset) and like other Users every 30 min laptop suddenly turned off. But...
Yesterday I found a solution which is as follows:
1. Dumped BIOS from EEPROM using external programmer (I using latest BIOS for this laptop ver 212),
2. Next used Hex editor for downgrade ME Region to 7.0.4.1197. I used stock/clean ME Region 7.0.4.1197 for this downgrade purpose,
3. I flashed back new modded BIOS with new ME Region,
..and after that, laptop was able to turned on, enter to BIOS, but couldn't boot from any connected media drive (ssd, usb)..., so I applied Linux version of "corna / me_cleaner " from github.
So last step was:
4. I runed "me_cleaner.py -S" script on my new modded BIOS with downgraded ME Region 7.0.4. In my case works first suggested option with capital S from me_cleaner instruction.
Thats it!!
After that my laptop is able to boot from any media drive and working without 30 min shutdown
note:
-my Asus X401A on HM70 had original BIOS with ME Region 8.0.10.1464
-donor Toshiba C660 on HM65 had BIOS with ME Region 7.0.4.1197
Maybe this will help those who are still looking for a solution. Hope it does
Best regards from Poland!Last edited by audifann; 12-09-2023, 07:09 AM.
