ASUS K56CB R505CB-SB51-CB LCD Problem
    Hi all, I am working on ASUS K56CB R505CB-SB51-CB. The laptop turn on fine & it only came in for the LCD screen replacement because the screen was blank & when I checked it with my broken Test LCD (14" 40-Pin) & all worked fine. So I ordered a Original LCD (40-Pin) from Screen Country, installed it but all line on the Screen. But on my broken LCD screen the display is perfect. The ORIGINAL is AU Optronics B156XW04 V.5, the one which Screen Country send me is AU Optronics B156XTN04.2, but I do get the display on my Test LCD which is also AU Optronics but a 14" one, Upon test it just divides the screen into 2 part but the display is viewable. What could be the problem??? can anyone put their tech thought on this. Thanks in advance.
    Re: ASUS K56CB R505CB-SB51-CB LCD Problem
    Below is the photo of what I get with the New Screen from Screen Country
      you should negotiate with Screen Country about the problem and report the result here.
