X555ld rev 3.3
  • hallmark1730
    • Apr 2021
    • 27
    Re: X555ld rev 3.3
    Originally posted by SMDFlea
    see posts 15 and 17 .The bios at post 17 has your DMI + win key added .
    Use neoprogrammer or asprogrammer software
    https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
    https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
    Thanks neoprogrammer is good list my chip mx25l6473e.Can I write the bios file directly? or do I need to find a dump file.i found a x555lb orijinal dump file Which one should I use
    3.3 volt mode mandatory?
    • hallmark1730
      • Apr 2021
      • 27
      Re: X555ld rev 3.3
      i try programing but error this
      Protection may be enabled. Press "Unprotect" and check datasheet
      Current programmer: CH341
      Old SREG: 01000000(0x40),
      New SREG: 11111111(0xFF),
      Programming memory(verifying)...
      Verification error on address: 00000005
      Execution time: 00:00:00.048
      SPI ID: 2017C2
      15:07:18
      Old SREG: 11110011(0xF3),
      New SREG: 01000000(0x40),
      Verification error on address: 0000000E
      Execution time: 00:00:00.049
        • 20618
        Re: X555ld rev 3.3
        Use the bios at post #17 ,i told you i added your DMI (serial number etc) and win key to it. Change neoprogrammer hardware settings to use ch341a . Manually choose the mx25l6473e ,then erase the chip,then open the file from post #17 and program
        • hallmark1730
          • Apr 2021
          • 27
          Re: X555ld rev 3.3
          I did the way you say. But I get the same error. please help me
            • 20618
            Re: X555ld rev 3.3
            plug the charger in,and the laptop off and try again
            • hallmark1730
              • Apr 2021
              • 27
              Re: X555ld rev 3.3
              if plug the charger do not read or write add picture.
              Even when I disconnect the usb, the light is on the programmer
              NEW EDİT:I don't know why, but now he programed it. Windows is opening, I will check if my video card problem is fixed
              • hallmark1730
                • Apr 2021
                • 27
                Re: X555ld rev 3.3
                You are a best.Thank you very very much.you were very patient, kind and helpful
                • hallmark1730
                  • Apr 2021
                  • 27
                  Re: X555ld rev 3.3
                  I'm very sorry. The graphics card is working properly.I wanted to do a clean install because the pc is slowing down after bios reprogramed.but windows installation stuck at copying windows files 0%.try different usb-iso-diskpart-bios secure boot disabled but dont work.I can't clean install
                  • hallmark1730
                    • Apr 2021
                    • 27
                    Re: X555ld rev 3.3
                    ok i solved it clean a contack cleaner for motherboard and harddisk board connector its work
                    • bilinch
                      • May 2015
                      • 19
                      • Turkey
                      #30
                      Re: X555ld rev 3.3
                      Try the attached bios,flash with AFUwin from here - https://www.ami.com/download/aptio-v...pdate-utility/
                      Thanks a lot 4 this correct bios for gt 940m. Code 43 error disappeared now. I change win key to blank and write the original case serial number to this bios.
                      Everything is perfect.
                      • khelane
                        • Apr 2015
                        • 159
                        • xxxx
                        #31
                        asus x555ld slow boot
                        hi
                        i have x555ld rev3.3
                        This device was programmed before it reached me and it has this problem. I tried a some BIOS now, but it is slow. It even shows the clean me file in the attachment.
                        I tested 3 or 4 BIOS, but it still shows up late
                        me BIOS version tested:
                        Version: 10.0.38.1000
                        Version: 10.0.30.1072
                        pls help me
                        tnx
                          • 20618
                          Re: asus x555ld slow boot
                          Post a picture of the sticker on the motherboard
                          Example https://i.postimg.cc/hP69RBW0/aaa.jpg
                          https://www.badcaps.net/forum/showthread.php?t=96604
                          • khelane
                            • Apr 2015
                            • 159
                            • xxxx
                            #33
                            It was my own fault. I had to clean the bios file myself. Instead, I went and downloaded the cleaned bios file. Finally, I made the BIOS with the appropriate me file and it was over
                            I attached the file for the site, maybe it was useful for someone
                            • vuhoang888
                              • Nov 2021
                              • Viet Nam
                              #34
                              My laptop is slowly boot. Please help. Thanks all. My model is (334) x555ldb.
                              https://i.postimg.cc/sgYdVzTW/P-20230301-192806.jpg
