sony vaio SVF15N1C5E bios
    hello this sony has difficulty in recognizing the hd in particular ssd, and therefore I can not install w10, I ask if it is possible to load the bios from dos with a bottable key
    thank you
    Re: sony vaio SVF15N1C5E bios
    thank you
    Click on the Assist button,enter bios,set to legacy boot .
      I tried but it does not see hdd ssd equally, if I put a mechanical hdd it sees it install w10 but when I restart it it does not find the system
        Post the bios backup .
          the backups of the bios can also be done without unsoldering the chip or do I have to unsolder from the main and put in the programmer?
            Desoldering is more reliable, but use a clip if you want to.Make 2 backups ,compare them with a hex editors File-Compare function (gave you a link to HxD in your other thread) ,make sure both are the same ,and look at the backups to make sure theres some code there. An empty file will be all FF ,comparing 2 empty files is not what you want .
              Ok ,thank you
                this it's the sony bios backup
                  try this one.
                  6C2000h
                  6CD000h
                    thanks, i try it
                      I can install w10 on mechanical hdd but on ssd, which is now seen, the installation comes to an end but on reboot it says:a disk error occurred
                        the problem could be the cable that connects hdd that I adapted since it was missing, probably the shielding of the tx and rx lines is not good?
                          yes, the problem was in the shielding of the hdd cable, I made the correct connections and now it works perfectly, thanks for your cooperation
                            bios sony vaio SVF15N1C5E
                            hi please i need dump for sony vaio SVF15N1C5E . my ssd d osent detected in bios, w ont boot an external drive, I've tried all the solutions and it didn't work
                            thnk you for help
                              Re: bios sony vaio SVF15N1C5E
                              thnk you for help
                              try the bios from post #9... don't forget to make a copy of the original bios before writing the bios chip
                                I tried it and it didn't work for me,mybe I have to replace the BIOS chip
                                  heeeeelp
                                    i tried it and it didn't work for me,mybe i have to replace the bios chip
                                    svf15n1c5e
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
