pls Bios HP Probook 450 G5
  • M1HX
    • May 2021
    • Slovenia
    #101
    Re: hp probook 450 g5 5 blinks on caps
    working thanks alot
    • Dreamcatcher
      • Aug 2020
      • Uk
      #102
      Re: pls Bios HP Probook 450 G5
      Hp probook 450 g5 daox8cmb6e0 rev e bios is corrupted can fix it
      • hopkok
        • Oct 2014
        • 178
        • Slovakia
        #103
        Hi everyone, Hp 450 g5 (DA0X8CMB6E0) UMA version with i7 CPU, not display and capslock bliking 5 times, fan at full speed. I tried clean ME, did not help, can anyone help me to rebuild attached dump? Thank you
        • peste
          • Dec 2016
          • 12562
          • ROMANIA
          #104
          try..
          • peste
            • Dec 2016
            • 12562
            • ROMANIA
            #105
            try..
            • habib_7_7
              • Nov 2015
              • 14
              • pakistan
              #106
              hi gays pls help me with this error
              How to fix WHEA_UNCORRECTABLE_ERROR
              HP 450 G5
              i change bios but no luck
              thanks
              • Genova
                • Jan 2020
                • 116
                • FRANCE
                #107
                Have a problem with 450 G5 caplock and ver num flash 5 times and nothing on sreen, any help please ?
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  #108
                  Originally posted by genova
                  hello,
                  have a problem with 450 g5 caplock and ver num flash 5 times and nothing on sreen, any help please ?
                  try dump from post#100 posted by mr.peste
                  • peste
                    • Dec 2016
                    • 12562
                    • ROMANIA
                    #109
                    hello,
                    try..
                    • Genova
                      • Jan 2020
                      • 116
                      • FRANCE
                      #110
                      Originally posted by peste
                      try..
                      Thanks it is all good, but where can i find some info like Feature byte, System board CT number, etc... ?
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #111
                        Given on the sticker
                        Or check on YouTube there is tons of video available
                        • peste
                          • Dec 2016
                          • 12562
                          • ROMANIA
                          #112
                          https://www.youtube.com/watch?v=9T57ktw8n3Y
                          • elghrib
                            • Jun 2021
                            • 3
                            • Maroc
                            #113
                            thanks
                            • Genova
                              • Jan 2020
                              • 116
                              • FRANCE
                              #114
                              Thanks but can not find CT number no more sticker on pc...
                                • 20618
                                Check inside the battery compartment, and enter your serial here to get some more info such as Feature Byte - https://partsurfer.hp.com/Search.aspx
                                • Genova
                                  • Jan 2020
                                  • 116
                                  • FRANCE
                                  #116
                                  Thanks SMDFlea, peste,qayyum786 CT number was the only missing one and this number was on the battery !
                                    • 20618
                                    You can find all the info in the bios using a hex editor,including the windows key. Text searches have to be in Unicode for the serial etc, apart from the win key which is in normal encoding,you can find that by scrolling down from the area where the serial is.
                                    • Genova
                                      • Jan 2020
                                      • 116
                                      • FRANCE
                                      #118
                                      Thanks for these infos
                                      • qayyum786
                                        • Aug 2018
                                        • 1933
                                        • INDIA
                                        #119
                                        Originally posted by jm801
                                        necesita ayuda con la reparación de bios, tiene 5 flash y luego el ventilador va alto y permanecer negro.
                                        try
                                        • qayyum786
                                          • Aug 2018
                                          • 1933
                                          • INDIA
                                          #120
                                          no funciona misma falla
                                          try this too
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • the_raz
                                            Need (unlocked) bios for HP Probook 450 G3 Notebook
                                            by the_raz
                                            I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                            Laptop number 1:
                                            Model: HP ProBook 450 G3
                                            Motherboard part number:...
                                            12-17-2024, 03:37 PM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
