Trekstor Primebook U13b bios needed
    I need dump of Trekstor Primebook U13b bios.
    It uses ic MX25L4006E with AMI bios
    Re: Trekstor Primebook U13b bios needed
    Could be the EC as its only 512KB . Post the backup from that and the bios chip when you find it .
      Here is the backup of that
        Ok. I found the bios chip. It's GD25LB64C
          Thats it, post the backup .
            Here is bios backup
              Here is bios backup
              33.8 KB? Not a very good job
              Try again (harder).
              Become a Badcaps supporter
              Thanks to all supporters.​
                Here is harder
                Sorry i had bad pin connection to programmer
                  Interesting thing that i noted. If i desolder BIOS and put in programmer it reads just fine.
                  But if i try to read BIOS directly from mother board with clamps (also i checked and clamps are making a good contact with all 8 pins) it reads wrong like the file that i sent you first time.
                  Could it be that BIOS is ok but something is "killing" it and because of that i get false reading?
                    Here is harder
                    Try this bios .
                      The same problem. When i pres power button the pwr led just flash once.
                      (also 3v3 is present only when the pwr led flashes once)
