Viewsonic n4060w w/FSP276-3F01 power supply
    Re: Viewsonic n4060w w/FSP276-3F01 power supply
    33uf 25v caps had 0.44R on the esr in circuit. Do I need to remove them and test again. Iv went though my caps and don't have any 33uf to replace them with. Ill get some ordered anyway
      You can use 47uF to try, what we are looking for is the start up voltage which you do not have enough for it to run right now.
      You may have bad IC.
        Ok I replaced the 2 caps for 47uf 35v and still not starting up.just the green led at the front. I take it 119volt on the 2 bottom heatsinks is normal? Should I order a new ic?
          If you still do get the 11V start up voltage then I would try a new IC.
          BTW, you did test the rectifier in the secondary to make sure they are not shorted or leaky? Also testing the board by itself with nothing connected for now.
            How do I test them?
              Hi i just been working on one of these now its all back together and working ok since re caping the whole power supply i have a fault all the side buttons work except the menu button also the menu button wont work on the remote either although it does transmit a signal checked with a camera phone so the problem i have is i cant set the colours/brightness etc. I have tried with all sources ie scart/hdmi/pc vga although all these work i still cant acess the menu function does this sound a bad mainboard? i cant find a code to use the remote to do a factory reset? i have just put the tv back together and running a soak test on it to make sure it that no heat related problems show up, so any ideas guys why only the menu function wont work?
                Hi guys just got back to this set its got one final problem i cant solve which is no hdmi sound. although picture is great ive looked in the service manual there are options to increase the scart sound etc which all work ok, one was set to 000 so i set is a per picture in the service manual that works ok too now but i cant find any options in the service menu for hdmi sound settings? could someone look in the service manual too see if im missing anything obvious many thanks (i have tried a eeprom reset)
                https://cdn.badcaps-static.com/pdfs/...36f5c56a24.pdf
                  amigos como puedo ensender la fuente n4060 de tv de 40 viewsonic afuera sin que esta en el tv la enchufe y le llegan sus 5v pero nesecito saber si salen 24 y 12 ya que es para un cliente por envio
                    above post translated reads
                    Friends how can I turn on the 4040 viewsonic tv source n4060 out without it on the tv the plug and you get your 5v but I need to know if they come 24 and 12 as it is for a client by sending
                      Thanks for translation. Could you translate the translation?
                        i was thinking that too haha, i think what he means he has 5v standby but wants too force the psu on without being in the tv to check 12 and 24 volt lines
                          Originally posted by dskall View Post
                          thanks for translation. Could you translate the translation?
                          lol!
                            That is what I think he is asking.
                              Pin outs, chassis as ground ref.
                              Service manual (not complete):
                              Do you have a full diagram that shows the values of all of the components? Please help or if someone know at least the values of all the capacitors please tell me, because someone tried to fix this power supply and he replaced the capacitors with different values and i need to restore it. Thanks
