original xbox power supply
    rev 1.0
    need to know what resistor r10 is on this board if anyone has one.
    i have an original xbox that has a power supply that this resistor has blown right off the board.
    it is in pieces so I cannot read what it was. everything else looks good and the xbox works with another power supply so i know main board etc are good.
    The other power supply isn't the same model as this one and it doesn't have this particular resistor on it.
    any help would be greatly appreciated.
    thanks
    Re: original xbox power supply
    39 ohms 5%
    If your supply is a foxlink ftps-0002 rev b at least. You didn't specify.
      mine is a ftps 0001 rev b and it's 39ohm, too
      R10 is a big resistor btw, what are you doing with your xbox to make that part explode?
        Does anyone here have a list of values for ALL the resistors on the FTPS-0001 rev B? Most of the ones in my psu have either faded color bands or they're browned from heat so I can't confidently tell what values they're supposed to be, knowing them would be helpful if I need to do repairs.
