Netgear = By far the most horrible support ever!
    Re: Netgear = By far the most horrible support ever!
    and routers dont need to use a "cloud" to administer the settings either!!
    They do that so they can sell you subscriptions....don't pay, you can't control your own hardware until you do.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      My Nighthawk router is still going strong... same model as the one I gave you (Topcat).
      But otherwise, Nutgear can take a hike... I've had hit and miss luck with them myself. I use a lot of thier pro-Safe POE switches in my volunteer work (FIRST Robotics competitions fields use one for powering an Airtight wifi sniffer over POE and connecting up a lot of peripherals to the main server cabinet). Can't say I've ever had to pull one from the case of spares. But with warranty support that crappy, I'd never buy one at market price!
      I'll use TP link for "dumb" devices (unmanaged switches, etc.) but anything smart I steer clear of (unless it's something I can put open firmware on). I don't trust them as far as I can kick them.
      sigpic
      (Insert witty quote here)
        i was looking at these:
        https://www.ebuyer.com/641041-tp-lin...ed-8-tl-sg108e
        it's amazing how cheap you can get a metal cased 8way gigbit switch with user management and diagnostics!!!
          I'm running that one in my house, set up as a basic access point....it doesn't need to do anything heroic other than provide WIFI coverage in the house. You have an open firmware on yours? If so, what?
          I have tons of those little guys I pulled from a K12 EDU. I haven't pulled a bad one out of the pile yet.....but what wrenches those for my application, I needed POE.
          Team : 49813
          Join in!!
          Team Stats
            yea, they have that option, but POE doubles the price!!
              DD-WRT.
              That said, I need to redo it on a newer firmware as Kong builds are abandonware. I've been stuck in "if it ain't broke don't fix it mode" except that it is broke (security issues, etc.) At my (as of July) former church I ran a similar R6300 V2 on newer firmwares and for the most part everything worked (it was also a SAMBA and FTP server via a USB 3.0 -> eSata external HDD). The two are so similar that I was able to do an NVRAM dump from my former R6300 (which was what I ran at my apartment) into the R7000 (which I scored right after buying my house) and it ran great and what the current setup was carried over from.
              It's used as a router and AP... a grand total of 3 SSIDs ("main" (2.4 and 5), "guest" (2.4 and 5), and "chromecast 5G" (5 only, to force the chromecast to not use 2.4 which would throttle it).
              sigpic
                i use OpenWRT
                https://openwrt.org/
                  i use OpenWRT
                  I've used it... for me, the potential performance gains aren't enough to warrant the difficulty of setup and maintenance. But I do have a few gigabit N Linksys routers on the shelf that are only supported by OpenWRT and have it installed.
                  Routers are something I want to work and work well... for me DD-WRT fits the bill. To each their own.
                  sigpic
