I had been using a WS-WN523N2 to generate WiFi from my wired ethernet internet connection. Recently it needed to be power cycled more and more frequently so I decided to open it up. I found 2 bulged 470uf 16V capacitors in the low voltage output side of the unit's power supply. The 2 other capacitors in the high voltage side, a 4.7uf 400V and a 22uf 100V both read low ESR so I decided to replace them as well. The 4.7uf 400V is directly across the output of the full wave bridge and the 22uf 100V is on the other side of an inductor coming off of the positive side of the bridge, negative side directly tied to negative side of bridge. The first time I put it together, I accidentally put a 470uf 16V across the bridge so on powerup in burned out the resistor between the AC input and the bridge. It's in one of the pictures, I believe it is 10 ohm 1/2 Watt by the color codes so that's what I replaced it with. This time with the correct 4.7uf 400V cap across the bridge, it powered up for a few seconds, then the new 22uf 100V cap on the other side of the inductor blew. It let out a loud pop and smoke. I'm guessing it got over-voltaged. So my questions are: Did I correctly interpret the resistor value as being 10 ohms? And also if the original was a wire wound, would it drop more voltage than the 10 ohm metal film resistor I replaced it with? Should I try a higher voltage rated 22uf capacitor in place of the 100V one? But I don't want to blow out any other components in the power supply if the voltage is running too high. Any input would be much appreciated.
Pictures of both the original and new resistors are included. I couldn't find a schematic or parts list anywhere online. If anyone has them, it would be very helpful. Thanks
