Hi everyone,
I'm probably going to ask a very noob question but after many readings and videos I'm still unsure on the answer.
I've broken one of the caps around the gpu of an xbox 360 by overheating it. In the forum I've found this thread where the user had exactly my situation (same console version and same broken caps): https://www.badcaps.net/forum/showthread.php?t=24983
The difference is that I've broken only one of the Rubycon caps (or at least that's what I can tell from a visual inspection). Now I'm planning to use a solid capacitor as replacement, as successfully done by the user in the thread.
My question is: can I replace only one capacitor or is it better to replace all the caps in parallel with it?
My concern is that the new capacitor will have a lower esr than the original ones and I'm not sure if mixing them could be a problem or not.
The original caps are: Rubycon mfz 820uF 6.3V (14x in parallel)
Will replace with: 820uF 6.3V solid capacitor (I'd expect any solid capacitor with such specs would do as the esr should be low enough as per nature of solid caps)
Thanks in advance
Thanks in advance
