I've got a Xbox 360 Elite with a Jasper V1 or V2 PCB as far as I know. 150W PSU and rated for 12.1A and the Xbox has the MFD 2009-10-14
Issue is that there was a lightning outside and now the ethernet does not work. Power cord was unplugged. Only ethernet cable was plugged in. The router and some other stuff died.
No error codes. Xbox seems to work as I should. When i plug the ethernet cable in nothing happens. Dashboard only tells me to plug in a ethernet cable. Or i don't remember.. if Ethernwr maybe was greyed out since it didn't recognize a connection.
No LEDs on my Switch when plugged in.
My suspicion is the ICS-chip that has failed. But I'm not sure. Just a guess.
Before i replace this chip are there any methods to use to verify it's the chip that's failed or if there are any other components on the board?
The RJ45 connector looks great, no bent pins or nothing.
Ive read on different forums and sites that the ICS are known to fail when theres lightning and stuff.
Found some schematics for the Jasper V1 and V2 and a boardview file if that helps.
Found here:
Or here: https://xbox360hub.com/guides/
Found here:
