Ps4 Slim firmware update stuck on 53%
    I have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
    Hdd is ok, it is tested with hdtune pro
    The Blu-ray worked perfectly before the update
    I tried several USB flash drives, no change
    The wifi module was changed does the same
    Can someone help me ? can the southbridge have problems?
    Re: Ps4 Slim firmware update stuck on 53%
    try connecting it direct to your router....not usb
      More likely to be hard drive than southbridge if you say its working
        Try ver. 10.50
          I tried with 3 different hdd + a samsung ssd + 4 different firmware versions v 6.50, 7.50. 9.00, 10.01, the console used to have version 6.50 and now it's the same, it works perfectly up to 53%, then it freezes
