I currently have a customer's vintage fan on the work bench to repair.
It uses an induction motor with 4 poles. One of the poles is open.
I couldn't find the break so i cut off the original wire.
I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
The enamelled copper wire for sale on eBay is listed in weight, SWG and AWG.
What would the weight be for 160M of 0.35mm copper wire.
Are these calculations accurate? It seems a lot.
