Macbook A1466 820 3437 no chime CPU hot
    Hello
    Just want to diagnose bad cpu and trash this away, but hope will not
    No water damage, no signs of corrosion, magsafe green then amber (no battery attached though), fan spin fast, and CPU gets HOT!! USB is 5vol present...
    U1950 is ok on all volts involved...
    any clues, thanks in advance!!
    Marcelo J
    Re: Macbook A1466 820 3437 no chime CPU hot
    vcore is present both, 1,72v
    Marcelo J
      History, USB activity, SPI ROM flashed, PLT_RESET_L present?
        PLT_RESET_L is present
        no water damage
        SPI ROM not reflashed yet but i wanted to make sure CPU is not toasted
        USB is 5v present,
        CPU Hot!, untouchable after 2 mins on, (with heatsink)
        Marcelo J
          check u1900/1950
          check spi termination resistors
          verify 3.3v on bios
          verify 33khz on u1900
            R6110
            r6111
            r6112
            r6113
            r6118
            r6119
            r6114
            r6115
            r6116
            r6117
            r6120
            r6121
            r6122
            r6123
            r6130
            r6131
            r6133
            r6132
            r6128
            r6127
            r6126
            r6125
              thanks paulyboy i will return this a1466 with no solution i think,
              An identical 820 3437 board shows 69.7ohm in the CPU coils (both) and this one at identical conditions shows 129ohms both... bad i think .and U1950 is ok on all volts involved...verified 3.3v on bios...
              although could not test:
              33khz on u1900
              because im about to return and is all packed, i think would mark this as a bad luck one
              Marcelo J
