iPad Air 2 A1566 Unable to Activate Help!
    Hi
    I have an ipad, it gives a red screen error and restarts. I re-molded the U1600 and U1800 ICs and threw in the software. Ipad is working but I can't activate it. I changed serial wifi blt emac, I couldn't activate it again, (i did unwifi ) I re-sofware every step to make sure, could it be another hardware failure? I would appreciate it if you could help me if you have come across and solved it.
    iPad Air 2 A1566
    Re: iPad Air 2 A1566 Unable to Activate Help!
    What does iTunes report ?
    Review some of the ideas here:
    https://www.ifixit.com/Answers/View/...+Flash+on+boot
      Thanks the methods here didn't work
        Then you may need something like this..
        US $24.00 | sn wifi bt serial number for iPad 2 3 4 ipad Mini 1 2 3 Air 2 iPad PRO 9.7 PRO 10.5 12.9 for iPad active icloud unlock
        https://a.aliexpress.com/_mqXw1fS
        There is a good video from a tech in Malaysia that does exactly this in the youtube video..activates the iPad with some serial number service.
          I have a different brand that does the same job, this device does not work.
            Originally posted by bodtech View Post
            Hi
            iPad Air 2 A1566
            If its prod date 2016, cant be activated. Go back to original serial and bypass only if its FMI On.
