Hello I have a main router hooked up to wan and sending out wireless. The wireless does not reach the other side of my house. I have lan going to another router which is configured as a switch. There is a cable going to the room I need wireless in. Is there any way to set up an old wireless router to take LAN and send out wireless?
Extending wifi
Re: Extending wifi
yes there is. using another router plug the cat5 line into a LAN port on the router not the WAN. Log into the router and disable DHCP, change the address of the new " access point" to one similar as your main router. example: netgear main router is 192.168.1.1 so make your new access point 192.168.1.11. the new access point must have the first 3 set of numbers the same and the last set of numbers should be below 249. I hope this helps.
Re: Extending wifi
Originally posted by agent35340 View Postthe last set of numbers should be below 249..
255 is not allowed, as is 000.
001 is default for routers, so I always use 254, which in this case is kinda "opposite" of 001. Makes it easy to remember when you have to work on something you installed 5 years ago, and the customer threw out the paperwork you gave them before you were even out of the door.
BTW, you want to configure this second router BEFORE you plug it into the network, or you may have trouble logging into it as the two routers will both want to be the DHCP server, and both will be at the same IP address.
Re: Extending wifi
I set it up so that it was connected to the switch that I have in the room I need wifi in but it takes a very long time to connect to. Many times the connection failes and the wired connections don't work most of the time.
Any sugestiones to why this is happening?canadaboy25
-Sometimes the light at the end of a tunnel is an on-coming train
Re: Extending wifi
As info,
1) 18 - 24Mbits with strength "Low" through two concrete floors (with iron cage), and sometimes even with strength "Good" (desktop - using extender coax cable 1,8m long, SMA connectors)...
2) 54Mbits at approx 10 meters through two brick walls (desktop - no cable)...
Re: Extending wifi
running perfectly fine at my mum's place, had to install a second access point there as the "superhub" that virgin supply is garbage on the wifi side (limited range).
I put the old belkin router we used with the previous sufboard cable modem downstairs in the lounge (superhub is upstairs), switched off dhcp on it, set it to the same subnet and SSID as the superhub and it works like a charm with wireless devices automagically choosing the device with the strongest signal.
At home it's a different matter, we share the inlaws' internet via a range extender there and due to my father in law's choice of hardware (whatever is going cheap on ebay, usually TPLink crap) our connection is always dropping out - mostly because the DHCP on his router craps out.
Re: Extending wifi
Take a look at DD-WRT firmware for your router(s). It's free under GPL, well supported in FAQs, Tutorials and Forums. It will allow you to make your wireless router able to do all the things it is capable of which are hidden/disabled in many native commercial router firmware.
http://www.dd-wrt.com/wiki/index.php/Installation
There are links to help determine if your router(s) are supported.
Re: Extending wifi
I find this:
http://www.newegg.com/Product/Produc...-187-_-Product
is one of the best extenders i've ever used. Just be sure your AP does not auto-rotate wireless channelCap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: Extending wifi
I've been trying to successfully set up this very repeater.
Alas, whenever I finish setting it up, the speed gets cut down by about 95%
(I get pure 33mbps down, 37 mbps up), to about 1/1 mbps on both.
What am I doing wrong?
I tried setting them on the same channel (without rotating them), same and different SSID, same width etc.
Would love to know if you have any suggestion.
Cheers!
Re: Extending wifi
We have been selling out customers the Netgear AC1900 instead of adding repeaters. The range on these things is far better than the Tier 1 routers that say Comcast or ATT provide. People with larger homes do fine with one of these in most cases. The only time it did not work for me was when the person had walls made of stone it was basically a castle. I do high end networking in the greater NY area for 20 years."Friends don't let friends drink and edit the registry"
20 yr IT professional Networking specialist.
Re: Extending wifi
I'd recommend Powerline adapters and a WAP on the other end (other side of your house) you will get better latency this way and have a hardline to plug into for greater speeds. This setup has proved most reliable for me, but for best results your house needs modern electrical wiring.Last edited by AFajitas; 01-08-2015, 11:00 AM.
Re: Extending wifi
Originally posted by AFajitas View PostI'd recommend Powerline adapters.
those bastard things put out so much RF that they mess up HF radio for a very long way.
the house wiring acts as a huge antenna!
several country's are about to start prosecuting people for using them.
https://hamgear.wordpress.com/2015/0...dband-devices/
Re: Extending wifi
- Military and governmental communication systems
- Aviation air-to-ground communications
- Amateur radio
- Shortwave international and regional broadcasting
- Maritime sea-to-shore services
- Over the horizon radar systems
- Global Maritime Distress and Safety System (GMDSS) communication
