Hey everybody, I am not certain if this is the correct place to ask but I have a Dell PowerConnect 2716 gigabit switch that I received from an employer that works and dies every so often.
When I got it, the switch didn't work so it sat on my shelf. I did open it and inspect the capacitors and they looked fine. Nothing seems out of place inside.
I eventually hooked it back up and it worked. It worked for a while then one day we unplugged the power and it didn't come back on.
Just today I hooked it up to try to test it and it powered on as if it doesn't have a problem.
I am guessing this has to do with my power supply but I am not certain what inside the PSU cause cause this intermittent issue.
Would any of you fellows have any suggestions on what I can test to diagnose this issue? I would really like to get it working.
Thank you
Thank you
