Need bios dell precision t3610
    Hi All,
    I need bios file for Dell Precision T3610. No Display problem.
    Here I attach backup original bin file
    Thanks In Advance..
    Re: Need bios dell precision t3610
    Hello ,
    did you solve your problem ?
    I need this bios too ,
    Can someone help ?
    Thanks in advance
      Originally posted by dmartins View Post
      Hello ,
      Can someone help ?
      Thanks in advance
      Post your bios dump and I can help you. I think that on this model have two bios chip, one for 8mb and de 2nd for 4mb
      (coloca aqui o dump da bios que eu ajudo-te. Penso que este modelo tem dois chips da bios, um de 8mb e outro de 4mb)
        Hello , mine just have the 4MB
        ( Obrigado , está complicado arranjar dump para isto , já anexei , abraço )
          Verify on board for another chip
          (O ficheiro que anexaste é a segunda parte da bios. Eu tenho aqui a bios A18 e são dois ficheiros, um de 8mb e outro de 4mb.)
            You'te right , ive seen the chip
            ( Tens razão , já o vi , estava mesmo a frente e nao vi.. Não tenho é programador para isto , o TL866 nao dá.. )
              Write the chip name that you can´t write with tl866.
              (qual é a serigrafia do chip que não consegues gravar)
                Originally posted by claudiomfa View Post
                write the chip name that you can´t write with tl866.
                25q64cvfig
                  25q64cvfig
                  The tl866 programmer write that chip without problems. select w25q64cv SOIC8
                  (O tl866 grava esse chip. Selecciona w25q64cv no programa)
                    Hi
                    I also have a T3610 machine with no video problem....Leds 3 and 4 are light and no post. Does anyone have a working bios dump for this motherboard?
                      Originally posted by hdd00 View Post
                      Hi
                      Post your bios backup here .
                        Hello, i have also a precison t3610 machine here with a corrupt Bios. No Display. The Board has a SOIC8 and a SOIC16 bios chip. Can you help me for getting two Bios Files to program it new?
                          read post # 11 ...
                            Here is my dump.
                              The machine is running again. I've done it myself.
                                thanks
                                  Here is my dump.
                                  thanks
                                    do you have a minute to upload the working bios? I'm in a tight spot. Please and Thank you
                                      If anyone's interested in helping. I'm still reading up on how to fix this. Thank you in advance.
                                        man thanks so much I didnt realize that this pc has 2 bioses the 8 pin an d16 pin one thats why when i flashed the 8 pin one the pc turns on and off.. lol I need to buy the other 16 pin clip and flash that too.. thanks so much
