Canon LBP 2900B Laser Printer Power Supply Board Problem
    Hi everybody, I am new to this forum.
    Please help me any one of you for my problem.
    I am a computer service engineer. I got a Canon LBP 2900B laser printer from my customer for service. It doesn't on. When i deassemble the printer, i could see the power supply circuit board ( RM1-2316 / 200V ) a resister (0.22 ohms) blown in the primary section. The blown resister is between 39mfd/400v capacitor and a switching transformer, this transformer is between the primary section and secondary section. A K2700 transistor is connected between the above said capacitor and transformer and also a YG862C15 transistor is connected to this transformer in the secondary side.
    I checked all the components nearby blown resistor are good, then i replace the resistor, again it blown, i confused and i decided to change the above said two transistors, again the same resistor blown, what would cause the resistor to blow.
    The sticker on switching transformer is (28EC-237 / TDK X 0933) 5 pins in the primary and 3 pins in the secondary which seems to be good, but i am not sure. how to solve this problem. plz help me. Thank you.
    Re: Canon LBP 2900B Laser Printer Power Supply Board Problem
    Clear focused pictures following my directions below exactly helps us help you.
    --- begin sig file ---
    --- end sig file ---
      Originally posted by RKRAJU View Post
      It doesn't on.
      I think you accidentaly a word there.
      Anyway, where do the traces from the resistor go?
        Most likely when the primary side transistor blew, the drive circuit for it popped too, causing the new transistor to be turned on all the time.
        Check the rectifier before the 400v filtering cap, make sure it isn't shorted.
        Remove the switching transistor and measure the resistance between its gate and the positive of the filter cap, and do the same with the gate to negative of the filter cap. Please report to us the resistances.
        The K2700 transistor is a 2SK2700 N-Channel MOSFET. The pins are from left to right: Gate, Drain, Source. (Looking at the front of the transistor that is!)
        Muh-soggy-knee
          Welcome, RKRAJU !
          The YG862C15 "transistor" is actually a high voltage 150V 10A twin common cathode schottky rectifier.
            Hello...
            is ur problem solved or not ,I don't know.But the problem is with one smd transistor backside of this board,which is feedback triggering pulses control of main MOSFET K2700.checkup that transistor.
              Hello friends, the topic is a bit old, but I have the same problem, I would appreciate if you could help me find a solution. Likewise, a 22 ohm resistor explodes. I change, it explodes again. Where exactly you call this MOSFET K2700, pictures are attached.
              1-
              2 -
              3-
              Thanks all
                1-
                2 -
                3-
                Thanks all
                1 - https://prnt.sc/239gv5u
                2 - https://prnt.sc/239gy4e
