dell xps 13 9300 fdq30 la-h811p rev:1.0 bios
    Re: dell xps 13 9300 fdq30 la-h811p rev:1.0 bios
    i hae the same problem with same motherboard did any get the solution i have flash many bin file but still the same
      If you have the original bios backup post it here in a zip or rar attachment
        there u have the original bios thank
          Unfortunately, it was a no fix, way too much time was spent re-flashing all the bios chips, and still the same error. You may have better luck, and I hope you do! Post back if you get it working I would been keen to find out.
            Try these
              Hi, I have the same problem. Are there any news?
                This is the problem of a defective CPU and connections between motherboard and CPU.
                You have to replace CPU.
                  ok, thanks for the reply.
                    Have you tried both the bios at post #25
                      9300 computrace can anyone help me
                      tag:2P8GM33
                        H everyone.
                        I have a Dell XPS 13 9300 with the same issue.
                        Dell logo and nothing.
                        I can't go to BIOS setup. Only LCD test mode works.
                        I've tried clean me firmware and same results.
                        I reflowed all RAM modules and CPU. Nothing changes—still Dell logo.
                        Anyone has a better idea of how to fix it.
                        The LED error codes 2 Amber and 4 White lists indicate RAM issue.
                        Has anyone managed to replace all modules and fixed this issue?
                        Thanks.
                          Originally posted by ronaldopdias View Post
                          H everyone.
                          Thanks.
                          UC23 fail, 1v8 falled 0.5V.
                          1.1V_MEM_EN =0.5V
                          +1.1V_MEMP falled 0.5V
                            1.1V_MEM_EN =0.5V
                              Dell XPS 13 9300, after clean OS install asking for corporate login. Can this be cleaned from the dump please?
                                This file could help you.
                                If the problem still present, take an image for the message and write your device Service Tag.
                                all donations are welcome,
                                  Thanks! Will try and report later.
                                    Stuck on Dell logo, 3 orange and 6 white led blinks.
                                    ST: 48C8W33
                                      ST: 48C8W33
                                      Here's your New BIOS, try it and let me know.
                                        My XPS 9300 is stuck at Dell logo as well. So far I have counted 5 Winbond 25Q80DVIG chips in various spots on the motherboard without lifting it and looking in the back.
                                        Can someone tell me the BIOS chip location? Thanks.
                                          Originally posted by trepachka View Post
                                          my xps 9300 is stuck at dell logo as well. So far i have counted 5 winbond 25q80dvig chips in various spots on the motherboard without lifting it and looking in the back.
                                          Can someone tell me the bios chip location? Thanks.
                                          uh8 kills near nvme plug
