I have a problem with an EVGA GTX 980 TI,
I have a problem with an EVGA GTX 980 TI it displays a black screen when starting a game on the menu for example either in HDMI OR DISPLAY PORT.
The basic problem is that the card does not boot, the FDMF 6823A mosfet shorts internally on the 12V line and I also changed an original one and now the card boots.
Driver installation OK
Detection of the card OK
No black screen on the desktop
No short circuit on the GPU
All voltages stable
The problem is when starting a game, black screen with the game sound in the background.
The problem seems to happen at a higher current demand on the gpu.
The card doesn't shut down and when I turn it back on the desktop is displayed.
Work done
- Changed again the controller by an original FDMF 6823A always black screen when starting a game (Value 6 Kohm on the 12 Volts seems ok), ohm test on the two internal mosfets at the gate ok about 30 Kohm) of the controller
- Flash bios by a new version always black screen in game.
What would be the cause ?
Is it a bad soldering of the FDMF 6823A?
What else should I check?
Many thanks to you =D =D
Translated with www.DeepL.com/Translator (free version)
All voltages stable
Work done
