Data lane - rtx 2070
    I have checked the pcie Lane in diode mode and the first data lane is showing 0v.
    Someone said that covering it with a tape would redirect the data to others lanes, the card should run fine on x8 pcie i think.
    Also someone said I could rewire 1st data lane to the last one, other data lanes give normal voltage.
    The graphic card got every voltage, 12v, 5v, 1.5v, 0.8v.
    The graphic card is not detected, the gpu heats up and the fans spins normally.
    Re: Data lane - rtx 2070
    sry mate. that gpu is mostly dead. u can check if it is not just shorted capacitor/s on that pcie line
    very often problem when insert 1x riser backwards
