MSI 1060 Aero 6G - Card working, not outputing to HDMI/DP
    I have a weird problem with MSI Aero 1060. The card works correctly, but most of the time doesn't display any picture through any port (HDMI/DP). When I remote into the computer I can detect it, read sensors, run apps (FurMark) without any problems, even though there's still no picture on any of the outputs.
    Few times it actually started and worked absolutely fine, which would point me to a faulty resistor - yet I am not sure where I should look, since from the schematics it looks like there's no common one part (except the core) that could fail and render all the ports not working.
    Any advice would be awesome. :-)
    Thank you so much!
    Re: MSI 1060 Aero 6G - Card working, not outputing to HDMI/DP
    Wash it in IPA some time helps
    I'm repairing the same card short on high side mos-fet and UP 9509 i gone .If you wont some measurements pm me .
    BTW i need to know the resistance on R744 R841 on my card some have 5K and 10K , and 202 ohm on the blown high side mos-fet ( resistors near mosfets ) .
      Actually yeah, it seems as cleaning all the ports helped.
      Sure thing, I will check those resistors and write the values.
