HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    HP BIOS unlock tool
    First check this site to see if your HP is supported for the great tool Mazzif has made.
    http://mazzifsoftware.blogspot.com/p...os-unlock.html
    If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
    For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
    When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
    Just program the new file on your bios IC.
    This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
    For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
    Code:
    Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
    Then modify that string adding
    Code:
    "C:\*location-of-exe*\HPUnlocker.exe" "%1"
    This way you just need to right click your locked file and select HPUnlocker.
    If there are any issues, please do let me know so I can improve this tool.
    All Elitebooks, Probooks and zbooks which are up to ninth generation which should be up to year 2018, like 840 G5, are supported. Newer models are not supported (yet atleast).
    No Pavilions or other trash is supported
    NEW multitool and unlocker added .
    Unlocking
    HP - ProBook, EliteBook, ZBook (including 32MB models)
    Chromebooks from all various manufacturers
    Apple - everything older than T2
    More to come...
    RCUnlocker https://www.badcaps.net/forum/showthread.php?t=98539
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: HP BIOS unlock tool
    Code:
    Code:
    Thanks or great work i appreciate..
    Or how i contact you personal?
    • RethoricalCheese
      • Mar 2013
      • 1517
      • Estonia
      You can contact me by writing here, by sending me a personal message or by sending me an email through my profile here (click on my name -> send email).
      I am working on some more tools, will try to post them aswell when I get them finished.
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        I not have access or option i contact pm or email.Then i send you our email or request tool...
        • itsmagic1
          • Oct 2019
          • 1
          The tool works great for a HP 830 G5. It unlocks my Administration Password!
          Thanx a lot!
          • marcin02152
            • Oct 2014
            • 134
            • Polska
            Working on ProBook 6470b. Tool Mazzif is "unsupported".
            Thanx!
            • ahok1213
              • Oct 2019
              • 0
              • Indonesia
              working on Elitebook 820 G3, thankyou!
              • fortinm
                • Sep 2019
                • 1
                • 81735518377
                thank you very much...
                internetpharmacydir.com
                • przemek_79
                  • Dec 2014
                  • 28
                  • Poland
                  thank you
                  • virginlulu
                    • Feb 2019
                    • 21
                    • China
                    Thank you!
                    • bachir2004
                      • Feb 2015
                      • 437
                      • maroc
                      Thanks for the nice work i really appreciate.
                      Will give feed back on every test.
                      • coumcoum
                        • Dec 2015
                        • 36
                        • algerie
                        hi
                        i download but not execut (Fatal error detected) - Failed to execute script HPUnlocker
                        • RethoricalCheese
                          • Mar 2013
                          • 1517
                          • Estonia
                          Put it directly in C:/ or D:/ directory and don't use spaces or some strange characters in any names. I had the same problem when I had space in folder name (like "locked bios" should be changed to "locked_bios").
                          I can't really fix that problem because I usually don't write computer programs so I don't know much about such problems.
                          I will try to fix it one day but I have some other BIOS unlocking projects right now.
                          • msdalaa
                            • Oct 2017
                            • 4
                            • Sweden
                            Not working
                            • foulou0238
                              • Mar 2014
                              • 109
                              • France
                              Hello This tool work with old Models ProBook and EliteBook like 8460p with old bios version the last version this tool won't work hp have the generator of SMC file
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                Msdalaa, what is not working? Send me your file, I will check.
                                Foulou0238, no, it works with newer versions too, like 840 G1, G2, G3 etc. Look at previous comments. If it didn't work with your file, send me your file, please.
                                • imranromi
                                  • Jan 2015
                                  • 1288
                                  • Pakistan
                                  I check this tool work for me 840 g3 100% without error
                                  • msdalaa
                                    • Oct 2017
                                    • 4
                                    • Sweden
                                    Hi
                                    i tried to open the tool but it doesn't work (Ftatl errer)
                                    this is my hp probook file
                                    • imranromi
                                      • Jan 2015
                                      • 1288
                                      • Pakistan
                                      Originally posted by msdalaa
                                      Hi
                                      You need just pick file and drop tool and done
                                      • RethoricalCheese
                                        • Mar 2013
                                        • 1517
                                        • Estonia
                                        Just used it and works fine.
                                        Did you put HPUnlocker.exe in C:\ or D:\ directory? If your directory has spaces or maybe some strange letters in it, it will give the error you wrote as I wrote before.
