Bauer tool battery pack charging with a HERCULES charger modification
    The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
    Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that the battery cells when bad
    Taking the BMS protection /switching power supply board from the Bauer charger and wiring it up to 2 amp hour battery pack from Hercules enclosure and be able to charge both brands of battery packs with one charger
    I will post some pictures when I am finished with this project
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
