ESR meter upgrades
This is a sticky topic.
    Re: ESR meter upgrades
    what cpu is in it?
      Atmega 644p
        good - because the replacement software wont fit a 324
        this is actually built for a 1284 but it should work i think
        it expects a 20Mhz crystal
        changed config files are included for viewing
          i forgot to say,
          you need to reprogram the 8 pin microcontroller that controls power, or replace it with a small circuit
            Thank's Stj have you found this better than the original.
              yes,
              lots of new features.
              but the biggest thing was the circuit for power.
              the original 8pin microcontroller seemed to not go into sleep-mode sometimes and was draining the battery
                Which ESR meter would you reccomend for testing caps in vintage solid state audio gear? Do i need LCR so i can measure at different frequencys?
                  vintage and solid-state arent 2 words you often hear together.
                  you mean 70's and 80's ?
