the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: the gutless, bloated, and fried power supply hall of shame
    Corsair pulled 335W from the same model under the raidmax name before the primary switchers went out.
      master hoarder
      • May 2008
      • 12168
      • Bulgaria
      #42
      Yes, and their last words were "That was spectacular!" .
      Also note the second primary switcher that is split in half
      Never noticed that until now . Fuse doesn't look like it's blown, though.
      • Tom41
        • Oct 2005
        • 336
        • England
        #43
        I posted this picture in another topic, but I might as well post it here as well. Behold a cheapo Nintendo DS charger, after a fatal short-circuit...
        (note the exploded IC and the soot on the caps)
        You know there's something wrong when you open your PC and it has vented Rubycons...
        • Wizard
          • Mar 2008
          • 2296
          #44
          Also the diode leads had blown out pits as well.
          Cheers, Wizard
          • c_hegge
            • Sep 2009
            • 5219
            I just got a dead "TT" branded PSU from a repair, where there are massive burn marks near the wires on the secondary side, Caps are all bloated and it took the motherboard out. Pics coming soon.
            • c_hegge
              • Sep 2009
              • 5219
              Just realised all the glue on the caps, but they're going to need more to stop them leaking.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #47
                It's an L&C...
                • c_hegge
                  • Sep 2009
                  • 5219
                  Originally posted by goodpsusearch
                  It's an L&C...
                  L&C=Deer=
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Its got some potential with those heatsinks.
                    • etnietering
                      • Apr 2009
                      • 379
                      That seems to be just like my "Super Talent" power supply that I posted about a while ago somewhere on this forum. After a full recap, upgrade of the secondary rectifiers, and upgrade of the primary filtering and bridge rectifier, it works great.
                      • cheese007
                        • May 2009
                        • 85
                        #51
                        That's some nasty heat damage near the secondary caps...
                        EDIT: grammar
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          its the opposite of a linkworld i just gutted, great filtering and wire, good rectifiers, etc. but he caps were bad and the heatsinks were TINY! good for parts only.
                          sigpic
                          (Insert witty quote here)
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4928
                            • New Zealand
                            #53
                            Originally posted by larrymoencurly
                            Compare that 250W Powsun to a 90W Delta/Newton:
                            I was going to say, there is no way that looks capable of 250 Watts.
                            I've got a 125 Watt Dell PSU with a board almost 3 times bigger!
                            -David VanHorn
                            • mur
                              • 21
                              #54
                              How is this powsun(leadman) working btw? It doesn't have 5vsb transformer, so everything must be on one transformer? And I don't see 5vsb switching transistor or ic. That would mean all rails are turned on all of the time?
                              edit: There is an ic on primary side, but I believe it's a pwm controller.
                                master hoarder
                                • May 2008
                                • 12168
                                • Bulgaria
                                #55
                                Good question. Perhaps there's only one rail that's constantly present and all of the voltages are generated from that rail. That's just a guess, though.
                                Or maybe that's not an ATX PSU?
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  that's actually supposed to be a 150W PSU. not 250W.
                                  http://www.powsun.com/pcpower_8868two.htm
                                  still.. interesting question..
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4928
                                    • New Zealand
                                    #57
                                    Maybe it's designed for Pentium 1 systems?
                                    -David VanHorn
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      It's ATX, it has 3.3v (the orange wires) and 5vsb wire (purple) as well as ps-on (green wire) and ps-ok (grey wire).
                                      The 5vsb is probably produced by the circled transistor or maybe IC in to-220 package.
                                      • mur
                                        • 21
                                        #59
                                        This is on secondary side, so I think it's a rectifying diode for 5vsb. Still not clear how it works on primary, though.
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          Here's another one. Four diodes, small transformers and small heatsinks. Primary caps are fuhjyyu, secondaris are nicon (no, I didn't mean nichicon) and Fcon.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
