the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    iMicro ATX3035-450
    Is there a limit to how many PSU's you can post? I can't believe this thing still works. It powered an Athlon 64 X2, GeForce GT440 system for who knows how long. And all that dust was acquired from a slow spinning thermally controlled fan. How did those BH caps not die?! And look at the secondary, it looks clean. I didn't dust this thing, I took pictures as is. BR is 4A, switchers are D304X rated at 12A, 30A on 5V, 20A on 12V, 20A on 3.3V. It does have a slot for a second 12V rectifier. I'm thinking about fixing it up. Although, it does have all 20AWG wiring...Haven't checked the solder side yet.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Re: the gutless, bloated, and fried power supply hall of shame
      Probably good enough for 150W continuous. 200W would be kind of pushing it.
      Probably. I really do think though that these cheap junkers with full boar running fans do better than expected. It's amazing how much of a difference good airflow makes.
      I never thought of this. Genius!
      Every project has to have some ghetto-ness to it
      Yes, should be possible.
      The easiest way would be to take the 5VSB transformer from this PSU as well, so that way you can transfer the entire 5VSB primary side on the new PSU. As for the feedback - almost all 5VSB circuits I've seen use a 431 shunt. Usually the compensation is a simple RC network and very similar between PSUs, so you may not have to change it all, unless the 5VSB has a hard time "keeping up" or overshooting with a load.
      Cool. And it's fairly easy to find a decent PSU with a 6105 controller.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #1023
        Originally posted by Pentium4
        Wow you know what, I'm so used to seeing ChengX in that green/gold sleeve that I didn't even notice that they're SAMWEI Never seen them before either.
        And here's a size comparison, that transformer is a lot smaller than the earlier pictures resemble.
        Cute
        Btw, the reason they use ICs for 5vsb instead of the 2 transistor circuit is that they score better standby efficiency and I think there is some regulation that requires it in EU.
        • Behemot
          • 4845
          • CZ
          #1024
          Latest version is under 0,5 W with no load, as I understand it.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Sentey BXP600
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              They're using Leadman now too?
              • SuperDuty
                • Mar 2011
                • 299
                • France
                #1027
                Here's the worst PSU I've had in my hands, an Ishaya 330U rated at 480W...hum yeah let's see that :
                First thing you'll notice, the size of the case :
                The amps are completely ridiculous.
                Inside, no protection, no PFC of course, just a typical very cheap PSU design
                I'm surprised they bothered adding two Y caps and a thermistor. The fuse is still good.
                That is fried, all the caps are bulged, aside from the two primary caps and the small ones. Yes there are jumpers where there should be coils, and caps as well. The caps are a mix of Canicon, Fuhjjyu and Jun Fu, top notch quality. The soldering is atrocious.
                A couple of 13007 as usual :
                Oh and that thing weighs approximately 300g I'd say. It was in a cheap case, powering a very basic 2005 computer : Sempron 2600+ socket 754, AsRock K8NF4G-SATA2, a 250Gb HDD, and a couple of optical drives.
                • PeteS in CA
                  • Aug 2005
                  • 3578
                  • USA, Unsure of Planet
                  #1028
                  Looking at the heatsinks, I was thinking 300W-350W. But the O/P transformer, the MJE13007-clone switch transistors, and those I/P rectifiers position it more in the 200W-250W range.
                  Is it a trick of the lighting, or is that O/P inductor as toasty as those vented O/P caps?
                  PeteS in CA
                  • Behemot
                    • 4845
                    • CZ
                    #1029
                    Yeah he wrote it is fried, I expect that goes for the black inductor
                    • SuperDuty
                      • Mar 2011
                      • 299
                      • France
                      #1030
                      Yes, it does look burnt, but it's not leaving any residue or burnt plastic smell so I'm not entirely sure. They're generally red/orange so I guess it is. The PCB is darker all around the coil.
                      • Behemot
                        • 4845
                        • CZ
                        #1031
                        It's black as coal and the same goes for the board beneath it, complete toast.
                        • PeteS in CA
                          • Aug 2005
                          • 3578
                          #1032
                          The chances that the magnetic properties of that core have been seriously degraded is pretty much a certainty, IMO.
                          PeteS in CA
                          • Heihachi_73
                            • Jun 2012
                            • 713
                            iCute ATX-320W/P4, date code 0324.
                            The power supply was pulled from matching "iCute" brand case powering a Pentium 4 system, which had a perspex side to show off whatever was worth showing off - the board was completely stock aside from a 2007-dated Geforce 7300GS.
                            Caps are a mixture of Fuhjyyu and CapXon.
                            Primaries: Fuhjyyu LP 470uF 200V
                            Y caps: TM 472M 2KV (standard brown film caps, not blue caps)
                            3.3V rail: Fuhjyyu TNR 2200uF 6.3V (bulged)
                            5V rail: CapXon KM 1000uF 10V (another matching KM between the two coils)
                            12V rail: Fuhjyyu TNR 1000uF 16V
                            Primary mosfets:
                            Q1: Fairchild E13007F2 242
                            Q2: Fairchild E13007F2 242
                            Q8: C5353 3.C (closest to fan)
                            Secondary mosfets:
                            D31: ST U1U319 MOROCCO STPS16 45 CT (closest to fan)
                            D32: ST U9Y311 MOROCCO STPS20 45 CT
                            D33: ST U50315 MOROCCO STPR10 20 CT
                            Transformers:
                            TEPN-EI33250 0321 HI-POT
                            10E190007-0N 0322 HI-POT
                            10L160009-0N 0320 HI-POT
                            11E250036-0N 0321 HI-POT (choke, listed here anyway)
                            Bridge rectifier (shock horror, it has one): SEP KBP06 - the board is actually marked for 4 diodes
                            Fan: Ruilian Science RDM8025SA (still working)
                            • TELVM
                              • Oct 2012
                              • 547
                              • Spain
                              #1034
                              ^ Outstanding "P4 support" with a 10A rectifier on +12V. "Overclock your Preshott to the sky and beyond!"
                              • cutegrandpalover
                                • Nov 2014
                                • 1
                                • usa
                                #1035
                                how long did it last?
                                • PeteS in CA
                                  • Aug 2005
                                  • 3578
                                  #1036
                                  Primary mosfets:
                                  Secondary mosfets:
                                  Transformers:
                                  Given that it apparently lasted for some 11 years, and seems to have just the one swollen/vented O/P cap (unless I missed something) some one seems to have sized that system to the P/S pretty well. And unless those fans were powerful enough for the P/S to hover, that thing might be good for ~200W. Those heatsinks, transformers, and switch transistors (Fairchild! A good brand.) are wimpy! One surprise, though, is an apparently genuine TI TL494 (TI created the TL494).
                                  PeteS in CA
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    Interesting, I have the "ATX-400W/P4" made a year later, and yours is built better!
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #1038
                                      Ipuke?
                                      Originally posted by heihachi_73
                                      icute atx-320w/p4, date code 0324.
                                      The power supply was pulled from matching "icute" brand case powering a pentium 4 system, which had a perspex side to show off whatever was worth showing off - the board was completely stock aside from a 2007-dated geforce 7300gs.
                                      Caps are a mixture of fuhjyyu and capxon.
                                      Primaries: Fuhjyyu lp 470µf 200v
                                      y caps: Tm 472m 2kv (standard brown film caps, not blue caps)
                                      3.3v rail: Fuhjyyu tnr 2200µf 6.3v (bulged)
                                      5v rail: Capxon km 1000µf 10v (another matching km between the two coils)
                                      12v rail: Fuhjyyu tnr 1000µf 16v
                                      primary mosfets:
                                      Q1: Fairchild e13007f2 242
                                      q2: Fairchild e13007f2 242
                                      q8: C5353 3.c (closest to fan)
                                      secondary mosfets:
                                      D31: St u1u319 morocco stps16 45 ct (closest to fan)
                                      d32: St u9y311 morocco stps20 45 ct
                                      d33: St u50315 morocco stpr10 20 ct
                                      transformers:
                                      Tepn-ei33250 0321 hi-pot
                                      10e190007-0n 0322 hi-pot
                                      10l160009-0n 0320 hi-pot
                                      11e250036-0n 0321 hi-pot (choke, listed here anyway)
                                      bridge rectifier (shock horror, it has one): Sep kbp06 - the board is actually marked for 4 diodes
                                      fan: Ruilian science rdm8025sa (still working)
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #1039
                                        Here is a nice one, the PSU itself is good, it's a Seasonic SS-250FS with Active PFC made in 2006.
                                        It was inside the really cramped PC for a bending machine, and the PSU fan had seized up some time ago, thus baking all capacitors...
                                        What someone has done to it is less than stellar though, I numbered the picture from least to most stupid:
                                        1: Green "Power supply on" cable soldered to ground. (I.e. To mimic an AT PSU).
                                        2: 5VSB cable unused and therefore cut off.
                                        3: 3.3v cables unused and therefore cut off.
                                        4: 5w "minimum load" resistor for 3.3v due to point 3.
                                        5: 3.3v "sense" wired to "minimum load" resistor in point 4
                                        6: "Minimum load" resistors leg has a blade connector crimped to it, which is screwed to a PCB screw, an extra negative cable has also been connected here.
                                        7: I think this is a ground wire in the "3.3v sense" circuit that has been connected to another ground wire.
                                        Next picture shows what has been done to the ATX connector, it has been cut off and replaced with this other connector.
                                        Now what surprises me is not this, the majority of machine manufacturers love to make proprietary designs, so the components need to be bought from them.
                                        But in this case they took a standard ATX PSU and spent probably more than an hour to modify it, and for what?
                                        They could have just bought an "industrial" PSU and called it quits...
                                        My solution?
                                        I bought a brand new AT PSU, an FSP SPI-300G.
                                        Cut off the connectors and wired them up to the proprietary one, then hid the 230VAC switch inside the computer, switched on.
                                        Bonus stupidity point: the computer itself requires 3.3v and thus has a DC/DC converter internally to produce that!
                                        • Dan81
                                          SNES-powered
                                          • Oct 2013
                                          • 1865
                                          • Romania
                                          #1040
                                          I've seen worser baking of capacitors,and here's one example
                                          A few days ago,I just got a half-decent Deer/L&C unit,a Premier LC-C400ATX. It sadly didn't work,so I had to get another PSU (because I was stupid enough to destroy my Sun Pro unit in the process) and I got some no-name unit with the UL number E231151. No results in the UL database,but I opened it and confirmed it's a Codegen from the heatsinks it uses. The fan had long ago seized,the PSU had quite heavy discoloration and badcaps of course!
                                          Gave it a recap on both primary and secondary sides (YongXing VZ(M) primaries and ChengX bulgers on the secondary ) using Seacon for the primaries and good Saturn (YC) caps for the secondary, and moved the board into the Premier casing. Got everything back together,installed it into my Pentium 4 and pushed the power button. Started up without a problem. Then I thought of recapping it with 16v 1500uf KY caps. It seems though,that something doesn't work as it should,as it sometimes turns on but sometimes it doesn't in the way that I press the power button but there's no sound. Just the power led comes on and it stays like that until I turn it off. It does the same now with the 1000uf 10v caps. (it didn't when I installed them the first time)
                                          Any ideas what it might be? I actually want to save this PSU even if it's a Codegen. I have 3 junk PCBs that I can take parts from.
                                          Main rig:
                                          Gigabyte B75M-D3H
                                          Core i5-3470 3.60GHz
                                          16GB DDR3-1600
                                          Samsung SH-224AB DVD-RW
                                          Delux MG760 case
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
